Beverley_Ken
Sep 27, 2021Explorer
Look on the inside of the driver’s door jamb, ours is just above the door latch. It is an ‘official’ FORD sticker for an incomplete motor vehicle. Lots of information on it for that particular chassis VIN number, Axle rating, tires that were originally installed, tire pressure for each axle as rated.
The bottom line, middle gives the axle code as installed by Ford, you will have Google Ford axle “83’ (my unit) for the specs.
It also gives the original Ford wheel base, in MY case it is 158”, Winnebago extended ours to 195” and also extended the frame at the rear.
Ken
Ken
