Effy wrote:
So I guess it's less about the space between the tires, and more about the space between the rims, provided the tire PSI is correct. Thus ensuring adequate space between the tires. Now, how in the world to measure the distance between the rims.. I am no contorsionist.
As I said, just measure the tires. In other words, the outer edge of the tread on one tire to the exact same spot on the other tire should be close enough to give you an idea. You should be able to just lay a yardstick across the tires and measure the distance between one edge of the inner tire tread to the same spot on the outer tire tread. If it is 11" or more, you are good to go.
