76_Rambler's avatar
76_Rambler
Rear gear ratio
I bought a 24 ft class c 1976 Holiday Rambler (E-350 chassis) last year, and recently had the motor rebuilt (ford 460). I ditched the motorcraft 4350 carb, and went with a holley 650 dp. I had them install a bigger cam on rebuild. It absolutely has plenty of power taking off from a stop, or climbing hills with no downshift. The transmission is a c6. The good thing is that it's a c6. The bad thing is that it's a c6, and has no overdrive, which means I'm running 2700 rpm at 55 mph and 3150 at 65. It was built when the federal speed limit was 55, and geared for that. I'd like to put a taller rear end in it to reduce my rpm's at 65. I'm just looking to see if anybody else has been through this scenario, and how far is too far on swapping the ratio. I know I'm going to lose power on the low end, and at the lower end of a shift. I'm sure I can make up for any bogging down after shifting gears with a stiffer shift modulator spring to shift at a higher rpm. I haven't lifted it yet to determine what's in it now.
