Kevin_Todd
Nov 07, 2016Explorer
rear axle gear ratio
Getting ready to move up to a 3500. I've shopped the available trucks, and have a good idea of what I want. The two I have narrowed down to are a '14 and a '15 Ram 3500. Identical with the exception of the rear axle ratio. One has the 3:73s and the other has 4:10s. I'll be towing a 5th wheel in the 18-20K range fully loaded,and by the spec sheets, both will do the job. I'll be running empty a lot, which way would you go?
