jd_h's avatar
jd_h
rear hub caps
I have a 2004 National Sea Breeze. One of my rear tires is loosing air. The local Goodyear dealer said he could fix it but I would need to remove the hub cap.
It doesn't look to me as if there is a hub cap. If that projection in the center is a hub cap, how do I get it off?
Thanks in advance for any advice.
J.D.
  • 45Ricochet wrote:
    Ebay for $15
    Sounds like you have polished wheels with the big hub cover in the center. They are called top hats and they make nice little plastic tool for removing them. Mine are Freightliner and I know Freightliner makes them. I keep one in the coach just in case.
    Since he's not bothered to return, I looked up his model on the net and, it appears it's a gas, class A rig and, most likely with a lighter duty chassis which, means wheel liners. And that means, it's not the polished alloy wheels and the rear Freightliner removable hub cover with the tool you show.
    Scott
  • enblethen wrote:
    And what was the solution?
    With 53 posts in eleven years I'm guessing we'll never know :B
  • Ebay for $15
    J.D.
    Well Sir,
    Since there are a few different types of rear wheel caps, liners, wheels, and more, my suggestion here would be for you to take a picture of your wheels and, post them on here. This will help immensely to figure out how things disassemble.
    Scott
  • Take the rig somewhere else.
    BIG O comes to mind
  • Do not know make of caps. They are more like long cylinders than hub caps.
  • My wheel liners are held on by some of the lug nuts. Remove chrome cover to access wheel lug nuts. My caps pop on over lug, some have plastic screw on covers.
    Do you know what make of caps or wheel liners?
