klutchdust
Jul 22, 2023Explorer II
wolfe10 wrote:
Bottom line is you/someone needs to crawl under and check the whole rear suspension. I would sure not drive it until verifying the issue and if serious, fix it now.
Even if not serious fix it now. Could be the center bolt in the spring broke. Look down the sides, is the rear axle tracking the same . Check lug nuts if you had recent tire servicing.
38,778 PostsLatest Activity: Jun 10, 2026
