Grit_dog
Jul 27, 2023Trailblazer
VA-Apraisr wrote:
Unique question from OP, so we're all just trying to offer suggestions. The post did mention "jolt from the rear". You suggested torque converter which is in the front. Nothing wrong with sharing unique problems and solutions that may in fact assist the OP. He could have a loose shackle/shock that just happens to relocate after applying brakes to full stop (another suggestion).
True, but I identified the TC as a highly potential source of this mysterious “bump” since the other suggestions can’t really do that if it’s sitting at rest (presumably in gear).
And if the TC were to lock/unlock or potentially some other component of the transmission, like the valve body and a late shift back to 1st gear after the vehicle is stopped, the first point of resistance, causing the thump that is felt would be at the rear diff because the brakes are keeping it from spinning.
38,778 PostsLatest Activity: Jun 10, 2026
