Dale_Traveling
Feb 26, 2014Explorer II
Images of the rear jack(s) installed. I needed about another foot or so of the retract hydraulic hose to make the install look a little bit better but it works for now. I had the mounting bracket welded over the fuel tank bracket. If I need to drop the tank four bolts and the jack is removed and the jack bracket is open in the center so I can get to the tank mounting hardware. I had room on the curb side to install the jack further back and avoid the tank mount but not on the street side. Only place without waste tank lines of the fuel fill was over top of the hardware. I have to watch for signs of corrosion on the jack mounting hardware. The bolts can not be replaced without cutting and re-welding the jack bracket. The silver stuff on the hardware is a heavy zinc antiseize.
38,779 PostsLatest Activity: Jun 16, 2026
