ghsebldr wrote:
Hi Spinners. I just went through the same thing looking for a slide controller for my 2004 Minnie. My mobile repair guy said I'd be lucky to find one, I didn't.
He said he could build me a double on off switch to make it work. He did bypass the controller just to make sure the slide motors were good and they were.
When he comes back I'll take some pics of what he comes up with. I think he will use the old controller and just jump around it somehow.
PM me if you'd like some pics of his work/switch. He made it sound pretty simple.
I Have a Tiffin Phaeton and for some reason the driver's side front slide is the only one of four that utilizes a relay to operate the secondary main control. The other three are directly driven from main 12vdc power. They all use the same size motor. While waiting for a replacement I wired it up with a self centering double pole double throw switch, center position off. It operated fine but I went back to the relay system once it arrived. I really don't understand why there was a relay, only for this slide but I took for granted that I should put it back like it was.
Now, to the point: You probably have the same or similar set up and a DPDT switch will probably put you back in business
