kitch251 wrote:
Thanks for the tip. I turned the converter off and can get the channels now, but ONLY buy putting in the numbers, which I can do. I wonder why the up and down channel change does not work however.
Again, thanks and if you have an idea on why I can't use the up and down to change channels, let me know.
Jim
as fischer wrote...there should be an AUTO PROGRAM on your TV's setup menu. with CABLE selected on the menu and the CABLE button selected on your RV's video switch start AUTO PROGRAM and all of the available cable channels will be located. please note that you need to do this each and every time you change parks just like you have to re-scan for the OTA channels every time you move to a new city.
