FIRE_UP
Apr 01, 2017Explorer
Kidoo,
This is not all that complicated. You don't say what chassis you have. I'm not all that familiar with Monaco and or, any chassis's they may use, if they're not Freightliner. I replaced my left rear hub seal about 4 years ago or so and it's been fine ever since. Not bragging, not at all. Just saying that it's a simple job and, if yours continues to leak or, at least starts leaking after a repair, obviously something's got an issue.
The seal, normally is installed in the rear of the hub. And, it seals on the axle housing, not the axle itself. I'm not sure what 11178adm was talking about in terms of a "Unitized" seal. And, also not sure what he meant by the statement that it (the seal) "does not rotate". If it's like mine, it HAS TO ROTATE, based on the fact that it's installed in the rear of the hub, and the hub rotates.
Now, I'm presuming that yours is like mine. If it's different, as in a total different design, then all bets are off. But it you take a look at the pics below, you'll see what I'm talking about. In the pics, you'll see the main hub, bearings, removed (bent seal) hub retaining nuts and locking/clocking retaining spacer. The hub it sitting on my table, with the wheel studs facing down. What you see as a silver tooth ring on the back side of that hub is the ABS rotator ring. The seal, fits and is installed, just inside the hub, just inside that ABS ring.
The rear or, inside bearing is installed, then the seal is pressed into position. It's that simple. But, if you're having the trouble with sealing you are, There's some checks that may be in order.
1. Pre-check the seal to axle housing surface with the new seal. Make sure it's a semi-tight fit.
2. Make sure there is no deep grooves from the older seals that were in place before. Even though seals are made of soft material like rubber, neoprene, viton and other substances, it's amazing that sometimes, they will wear in a groove on the housing that they ride on, causing a potential loose fit which can cause a leaking situation.
3. Make sure the seal fits snugly in the hubs housing.
4. The seal, again if it's similar to mine, needs to be installed with great care. That is, it must be installed either with a specific seal installation tool or, at least if the tool is home made, it must be in contact with the entire circumference of the seal-back, as the seal is being either driven in or, pressed in.
If a seal of that size is "hammered" in, in a rotational method, that is if it's pounded in a little at a time, as you pound around the entire seal-back, it's highly possible to warp and or distort that OUTER sealing surface of the seal, the part that seals against the hub, not the rubber side that seals against the axle housing. If it gets warped or distorted, it's possible that, that's where your leak is emanating from.
I have the pictures you see below. But, I do not have a picture of the exact surface your seal rides on, the axle housing itself, in Photobucket, where I store on line photos. Again, if this situation is not like yours, then all this is worthless to you. Good luck.
Scott
Scott
38,766 PostsLatest Activity: Jan 10, 2026
