wildmanbaker
Jun 08, 2016Explorer
could be the seal, or the axel gasket. Sometimes the bolts holding the axle to the hub work loose and leak. If you are going to do this yourself, try to find out exactly which rear end you have and acquire the other seal and axle gasket ahead of time to save yourself some headaches. You will need a pretty large jack to support the rear end for the work.
38,769 PostsLatest Activity: Apr 03, 2026
