pigman1
Jun 08, 2016Explorer
rgatijnet1 wrote:Yep. Check the bolts for tightness first. I've had this problem 3 times on 3 different coaches and each only required tightening the bolts. A good thing to put on your periodic check list too.
It may just be the seal on the end of the axle shaft. Very common for them to leak. They basically just pull the axle out, clean the surfaces, apply gasket material, and slide the axle back in. About a 30 minute job.
38,769 PostsLatest Activity: Apr 03, 2026
