KPruitt's avatar
KPruitt
Rear wheels off the pavement
Hi,
Everyone! New member and need some help. I just purchased a 2007 Holiday Rambler Neptune been doing some discovery learning parked in my driveway. My auto leveling system when engaged puts the jacks down the panel reads that the rig is level, not so it raises the rear wheels off the pavement. The Manuel tells you not to lift the tires off the ground. Is there an adjustment I can make to fix this?....
  • If you have your rig in park and the parking brake on and you lift the rear wheels off the ground, the only thing holding it from rolling away is the levellers.
    If the slope is steep enough you could bend the jacks.
    I have lifted the front wheels off the ground when the ground was very uneven, but I try not to lift the rear wheels off.
