dougrainer
Jun 08, 2015Nomad
ALL 4 door 1200/1210 series Norcolds get the recall kit. Failure of the recall can be caused by slow drain on the coach batteries. NOT sudden loss like a battery disconnect. You CAN reset with the magnet method already mentioned here. But, I have found resetting works better with NO 12 volt to the recall box, disconnect the ground or battery power in when using the magnet. Failure can also be the result of the recall doing its job and the CU has leaked the ammonia and the temp goes over the 700 degree threshold to trip the recall box. Failure of the recall is rare. I rarely have to reset or get a customer in that has had a non CU leaker causing the failure. IF someone has had more than 2 recall boxes AFTER the REV E, then I would suspect the install was not done correctly. Doug
38,782 PostsLatest Activity: Sep 10, 2026
