mikeleblanc413
May 04, 2013Explorer
lanerd wrote:mikeleblanc413 wrote:
The batteries I currently have in the coach are Duralast Marine Batteries, 800 Cold Cranking Amps...I've check the fluid levels and the connections...all are well...if replacement is the answer...what is a battery you've had excellent service with?
I believe those are NOT deep cycle batteries, rather starting batteries since they are measured in CCA. Deep cycle batteries are measure in AH (amp hours).
If this is the case, that's your problem. Get rid of the starting batteries and get deep cycle ones.
Ron
What is the difference between starting batteries and deep cycle batteries?
38,782 PostsLatest Activity: Sep 10, 2026
