- loggenrockExplorerx3 for ReadyBrute! Over 30k miles towing a Suby Forester ~3200#. Actually lighter weight setup and less costly than many others, in addition to simply working!
- F1bNormExplorerX2 No brake box sitting on the drivers side floor.
way2roll wrote:
Your base plates will be dependent on your vehicle. We use Blue ox baseplates but have the Ready Brute Elite tow bars with integrated surge brakes. I really like these bars, everything is mechanical so there is nothing electrical or pneumatic to fail on the braking system. And the brakes are built into the bars so there is no installing/uninstalling the brake system like on a lot of other brands and it's not invasive to the vehicle. Takes about a minute to hook everything up from start to finish. Super easy. They were a little more expensive than some other brands, but when you consider the brakes are built in, but they are comparable to a set of bars and additional brake system, so in the end it's a wash. We tow a CRV.
ready brute bars - memtbExplorerIt appears that Blue Ox and Roadmaster both offer base plates for our “Toad”.
- MDKMDKExplorer
memtb wrote:
For a better explanation: We will be doing a bit of off-road use, with the occasional use as city/town ( which we avoid)....and have a Suzuki Samurai! Hence the light weight!!! We will rarely use a conventional RV park/campground....mostly National Parks/BLM/State Parks/boondocking, ect.
So.....we’re looking for a good tow set-up for the Samurai. We will be towing ....4-down! We’ll be looking for a hitch capable of 5K plus pounds, in the event we get “old” and change our lifestyle!
Thanks again.....and sorry for the confusion! :)
No worries, just wanted to get clarification on what you actually wanted. See my prior post on Blue Ox. Good stuff, great support. - way2rollTrailblazerYour base plates will be dependent on your vehicle. We use Blue ox baseplates but have the Ready Brute Elite tow bars with integrated surge brakes. I really like these bars, everything is mechanical so there is nothing electrical or pneumatic to fail on the braking system. And the brakes are built into the bars so there is no installing/uninstalling the brake system like on a lot of other brands and it's not invasive to the vehicle. Takes about a minute to hook everything up from start to finish. Super easy. They were a little more expensive than some other brands, but when you consider the brakes are built in, but they are comparable to a set of bars and additional brake system, so in the end it's a wash. We tow a CRV.
ready brute bars - ron_dittmerExplorer III
memtb wrote:
That is us too. We do our best to avoid private camping.
We tow a 2006 Jeep Liberty, also for the same reasons you mentioned. We used to tow a tiny car but quickly learned that we needed a 4x4 to address the adventurer in us. - bobndotExplorer IIIYou need to find which company makes a baseplate for your vehicle then match the tow bar to it.
Towing procedures are vehicle specific. - memtbExplorerFor a better explanation: We will be doing a bit of off-road use, with the occasional use as city/town ( which we avoid)....and have a Suzuki Samurai! Hence the light weight!!! We will rarely use a conventional RV park/campground....mostly National Parks/BLM/State Parks/boondocking, ect.
Thanks again.....and sorry for the confusion! :) - harley-daveExplorer IIWe tow a 3200 tracker with a Roadmaster Sterling tow bar and base plate. Demco Stay-n-play Duo semi-permanent brake system. We had a charge line installed in our E450 based C to keep the car battery charged and LED lites installed for toad lights.
Dave - MDKMDKExplorer
MDKMDK wrote:
Blue Ox. They can provide all the hardware you'll need to tow 4 down (flat, no dolly or trailer), and their product support is great, in my experience. I'm not sure how they fare as far as price goes, but I think they're worth it.
OK, before we get any further into this, could the OP please define the topic a little more clearly?
Topic: "> Recommended Tow Set-Ups (Brands) for the Toad"
OP, does this mean you want suggestions for towing hardware brands, like Blue Ox or Roadmaster or Brake Buddy, or for other options for towing, like trailering or tow dollies?
Comments "We’re finally getting a “Toad”, and would like opinions and suggestions. The “Toad” weight will be under 2500 pounds. We will be doing a lot of mountain towing! Thanks in advance for any and all help!"
OP, does this mean you've already selected a toad that weighs under 2500 lbs?
Most of the replies to your thread so far have been suggestions for the actual toad itself, which I think you've already selected.
I read this topic to mean you wanted help with the towing hardware required to pull a 2500 lb toad, sometimes through the mountains.
Your turn, memtb ......:?
38,778 PostsLatest Activity: Jun 10, 2026
