clotus
Jan 22, 2022Explorer
brooksrimes wrote:
We have a 2021 Jayco Greyhawk 29MV, class C.
Attached are links for a Hellwig 7180 rear sway bar, a Supersteer SS451 rear trac bar and rear Sumo springs SSR-130-54. Which would have the greatest benefit in reducing the push/pull from large tractor trailers passing us on the interstates?
https://www.hellwigproducts.com/products/search-by-vehicle/?Year1=2021&Make=Ford&Model=E-450+Super+Duty
https://supersteerparts.com/products/supersteer-ss451-rear-trac-bar-for-ford-e450-2021-v8.html
https://supersteerparts.com/products/rear-sumosprings-solo-kit-for-ford-e350-e450-ssr-130-54.html
Don't all the Greyhawks come with Jayco's J-ride system which is essentially bolts-on/shocks. I would ensure you don't already have what you have mentioned.
I am pretty sure you do not have a trac-bar, which I found really helped. Then I got an alignment, added caster, and man so much better!
