chuckftboy
Jan 13, 2015Explorer
prstlk wrote:
2007 HR Ambassador Norcold 1200 fridge.
Noticed small amount of water dripping from the LPG tank door bay. (Almost 1/3 back from the from the front of the coach on this model). Tracked it to the fridge compartment, only one outside access door on this model mounted low. There was water dripping slightly from out of reach and out of vision toward the the back/top of the unit.
Shut off the water to the icemaker, leak stopped. Looked gawked shown lights etc and found no access to the line.
Called a mobile tech we have used and trusted to take a look.
His dio was line failure at the top of the fridge were the line enters the freezer.
Repair means removing the fridge to replace the line. $300/$400.+ Parts
Service contract is no help. (Sorry parts made of plastic rubber or vinyl are not covered)
I can by lots of bags of ice or use trays....but things that don't work #iss me off.
Questions.. What if...
Does the sollaniod on the back of the fridge that I can see determine the how much water goes into the tray in the ice maker.
If so what is wrong with drilling a small hole in the back of the frezzer above the exsisting line and running a copper line down to the valve/solinoid.
Thanks to all in advance.
You have saved me a pile over the years!
jw
to answer your question, Yes you could run a new copper line (1/4" OD) from the solonoid valve to the ice trough. It would work fine
38,774 PostsLatest Activity: Mar 01, 2019
