dougrainer
Jan 14, 2015Nomad
1. You will not be able to drill a hole and snake a new line(plastic or copper). If you pull the refer, you will see why.
2. The ejection motor IS the timer and as it turns it opens and closes a BIN switch or contac the required amount of time to allow the correct amount of water to the tray. Doug
38,774 PostsLatest Activity: May 13, 2026
