Wally_Walleye
Jan 14, 2015Explorer
We had to have this done on our Dometic a few years ago. Did not cost that much and it was a mobile service. They did have to pull the frig out and replace the line. Are you in Idaho now or are a snow bird? Also If you are a member of FMCA call them tell them you have a water leak they may pay for the service call.Not the repair but the service call to check the leak. The only other thing to check is the fill screw on the front of the ice maker. If too much water is coming into the ice tray the excess water may be leaking through the drain tube at the bottom. Do you also have extra water in the ice cube bin? You will know if you have a block of ice in the bottom along with solid ice cubes. Good Luck
38,774 PostsLatest Activity: May 13, 2026
