DSDP_Don
Jan 14, 2015Explorer
"prstik"....Typically, Monaco mounted the refer with two lag bolts on the back, at the bottom via the outside access door. The front of the refer has a trim, that when removed, exposes several screws that hold the refer in place. Once these are moved and the gas line is disconnected, you can slide the refer forward in the opening.
Now you have two choices, find a small skinny teenager to slide up in the outside opening, or try and access from the roof. Remove the roof vent cover, cut out the screen material and reach down and access the line. Use some screen door mesh to reseal the vent.
38,774 PostsLatest Activity: Mar 01, 2019
