FIRE_UP
May 28, 2013Explorer
mark52,
First, I find it a bit odd that you have no gravity fill. I'm certainly not an authority on all motorhomes ever built but, I've had a gravity fill on all four of ours but, that's another story. Anyway, As you've already figured out, just tap into the intake side of the pump or, install a check valve right behind where your pressure fill is, (if you can get access to that area) and put your additional filling system in that way.
Now, as far as a pump is concerned, don't goof around with any other pump than, a standard water pump for an RV. Sure-flow makes a dozen different pumps at various gph ratings and even different pressures. The good part, they're 12 VOLT! And, one other serious good point, THEY NEED NO PRIMING! You can setup the pump on a small board (platform for mounting), some nice, flexible hoses, one into the water jug and the other into your new filling system. Then, all you need is a "cigarette" lighter type power plug, with or without a switch and fuse etc. and, plug in your pump and make sure your hoses are in place and, have a cool drink while your pump is working away and, the jug can be on the ground. Done!
Scott
Scott
38,782 PostsLatest Activity: Sep 10, 2026
