zman-az
May 28, 2013Explorer
As mentioned, use the winterizer feature of your motorhome. When using it just turn the inlet valve to the fill position and turn on the water pump switch. Easy Peazy.... It's free, no need to buy a second pump and hook it up. For those that do not have the winterizer feature you can buy a 3 way valve.
As far as more grey water. If you are in a place where you cannot dump you can purchase this device to transfer grey water into your black tank. Just close the new valve, open grey water, open black water and the grey should fill the black water. Of course if your black tank is higher or fuller than the grey water tank you could reverse the flow. I don't bother with the garden hose setup but its also a nice feature.
Camco PN 39062
Camco PN 39062
38,782 PostsLatest Activity: Sep 10, 2026
