mark52
May 28, 2013Explorer II
zman-az wrote:
As mentioned, use the winterizer feature of your motorhome. When using it just turn the inlet valve to the fill position and turn on the water pump switch. Easy Peazy.... It's free, no need to buy a second pump and hook it up. For those that do not have the winterizer feature you can buy a 3 way valve.
are you talking about the pipe coming off of what appears to be on the inlet side of the pump (see my set up in the picture above. if i unscew that cap and connect water to it, it seems that it would go strait to the MH sinks and not fill up my tank. is this how yours is set up?
38,782 PostsLatest Activity: Sep 10, 2026
