dougrainer
Aug 25, 2019Nomad
ferndaleflyer wrote:
I have discovered a similar problem. Have yet to check why but mine does not automatically switch to propane when electric supply (shore or generator)is cut off. I can manually switch it to propane and it works fine. Don't know if it will switch the other way.
If your refer has the AUTO switch, it will switch back and forth when you connect or disconnect 120 power. The default on AUTO is 120 if 120 is connected. Doug
38,766 PostsLatest Activity: Jan 10, 2026
