supercub wrote:
Perhaps you could call the Refrigerator manufacturer and ask them what the draw is.........that should give you some idea.
Brian
You forget---Draw has NOTHING to do with it. It depends on how often and how LONG the refer runs. Below is the spec for the 1200. Doug
DC amp draws (at nominal 12 Vdc)
Automatic ignition-------------------------------------------------------------------------------------------------------------------0.50 A
Moisture reduction heater and divider heater--------------------------------------------------------------------------------0.70 A
Fresh food compartment lamp--------------------------------------------------------------------------------------------------0.46 A
Gas valve----------------------------------------------------------------------------------------------------------------------------0.146 A
Fans (2)-------------------------------------------------------------------------------------------------------------------0.30 A (per fan)
