- DrewEExplorer IIIIs it just the interior light that doesn't work, or the fridge as a whole?
Could bed a bad house battery, as mentioned, if nothing 12V works. It could also be that the battery disconnect (commonly called a salesman's switch) is in the disconnected position, and simply turning it on will bring everything back. It would seem not to be the fuse for the fridge's 12V circuit in as much as it does work sometimes. - Old-BiscuitExplorer IIIMore info......
Fridge
When light works/doesn't work
Does other 12V items work
More info..... - SCVJeffExplorerWhat does "wont stay on" mean? It won't come on at all, or it goes out after a specified period of time (as it should) ?
- ParkCountryExplorer III suspect a switch problem. Exercise the the door switch and observe that the switch opens when you release pressure on it.
- Mandalay_ParrExplorerSounds like your 12v battery circuit is nor working. Might be bad batteries.
