Old-Biscuit
Oct 17, 2013Explorer III
Thermistor....
If it falls out of clip or it and clip fall off cooling fin in food section the fridge will continuously cool........same thing will happen if thermistor is bad.
Find your thermistor......couple wires come into food section and on the end of those wires is a small sensor. If it has fallen down...place in plastic clip with bulb just protruding at top and then slide clip onto far right fin mid position.
Wait 24 hrs. for temps to stabilize before making any adjustments to temp control settings.
IF thermistor is in place on fin then it is faulty causing fridge to continuously cool. Replace thermistor.
Here is an easy replacement kit......LINK
38,763 PostsLatest Activity: Dec 13, 2025
