Geno92308
Oct 08, 2015Explorer
Why not run your generator for the first hour as part of your shake out? Check the oil and altitude setting (if not injected). On the genny, run the ac's and vacuum. That will run the genny , do the initial charge on the batteries, run the ac's (even if not necessary). Shut off the ac's, then switch to shore power for the battery top off and fridge for hours.
In the long run you may want to have a 50 amp receptacle installed and 50 amp cord long enough to use.
The vacuum is a lot of amp draw, and your charger can draw a lot of power as well.
38,766 PostsLatest Activity: Jan 10, 2026
