- J_WalkerExplorerThe roof A/C probably have the relay located somewhere on the unit. It would not make sense to locate it remotely. You can get the make of the A/C and call the manufacturer. That should answer the question.
- Flyfisherman128ExplorerIf you have a low voltage thermostat them you probably have relays. If you have controls on the unit you probably don't have relays.
- bigfish7420ExplorerThe roof air, its a 1997 American tradition (feetwood)We had air conditioner techs look at it, sometimes it will come on and work just fine for a while then it will just stop, everything on it checks out, compressor,fan, thermostat, he said something about the relay switch, and the power to it, but we cant't locate them
- robatthelakeExplorerAre You referring to the Roof Air or the Dash Air?
what Make And Model is the A/c ?
38,783 PostsLatest Activity: Sep 24, 2026
