wildmanbaker
Apr 03, 2015Explorer
O.K.
What are you two wanting? In both cases, something needed to be removed from the fuel in order for the clean-up to work, on a extended basis. Gas, was lead, diesel, was sulfur. Problems, gas, valve seats and valves did not like the anti-knock replacement for lead, which is also poisoning our ground water, which the oil companies tried to tell them, but oh well. Problems diesel, removal of sulfur, which caused leaks and some loss of performance/mileage. The fix, different material for seals/gaskets in the fuel system. These are the facts that I know/experienced, if you do not like them, I sorry. Just like the "Laws of Physics", I cannot change them. If you do not agree, fine, unless you subscribe to the theory of if you repeat an old wives tale enough, it becomes fact.
38,782 PostsLatest Activity: Sep 10, 2026
