saddlesore
11 years agoExplorer
I have a '99 Four Winds / Thor Infinity that has the TV in the dash.
What I did was pull out the old TV and then used a small sawzall to trim the front of the plastic cover so the flat screen would set vertical against the dash. Then used a lockable position wall mount. I drilled the holes to mount into the engine cover (with a 3" x 6" backing plate)and mounted the TV.And used the old TV strap to hold the top in place.(felt that more tie down points couldn't hurt)
The reason I did not put the TV in the overhead bin/ceiling is that I have seen several that there wasn't enough support in the overhead structure to support the weight of a large flatscreen and when the mounts failed tore the hell out of the overhead or ceiling, not to mention what the end result to the TV was.
Hope this helps.
Hope this helps.
38,781 PostsLatest Activity: 12 hours ago
