bobndot
Feb 21, 2021Explorer III
On horizontal surfaces use Dicor self leveling.
On vertical surfaces , I switched from Proflex to 3m 4000 uv. It is very uv resistant and a lot easier to apply than the Proflex.
Both last and work well but you need to use ‘brite white’ in Proflex otherwise it will tend to yellow. The 3m goes on easier, it makes a nice even line when you use a wet finger to smooth it.
Apply a fine mist of denatured alcohol to the caulking bead using the spray bottle. The alcohol keeps the caulk from sticking. Use your index finger to smooth the bead of caulking with your finger before the alcohol evaporates
38,782 PostsLatest Activity: Aug 31, 2026
