dougrainer
Sep 05, 2018Nomad
Your year Newmar, 2 ways they installed the wood trim ring
1. You go thru the TV side overhead door compartments. There will be either 2 or 4-- 4 inch long screws thru the cabinet side into the wood frame. You remove those screws and the wood trim ring pulls out. Usually there is an overhead metal bracket you will see attached to the top of the TV and screwed into the ceiling of the TV cabinet and there will be 2 screws into the tv cabinet floor thru the TV mount feet. VERY HEAVY CRT TV. Have someone hold the TV when you remove the screws and you will have to have this person hold the TV while you disconnect the Power cord and Coax from the TV and wall receptacle.
2. IF you have the smaller TV, the wood trim ring had wood plugs on the front and you remove those plugs and unscrew the trim ring. Doug
