msmith1199
Sep 08, 2013Explorer II
In this photo you can see the bottom of the steel box holding the TV. I've removed 4 of the six bolts and stuck screwdrivers in the hole so the TV doesn't drop out as I remove the other two. You see see in this photo the TV sticks up into the ceiling several inches. Otherwise it would just slide out. I'm guessing they installed the TV before they put the ceiling in. Now I have to drop the bottom of the steel box to get the TV out.
After this photo I removed the last two bolts and the TV is still sitting there with the screwdrivers holding it in. After the 49ers game I'm going to go out and try and get it out. One problem I see I'm going to have is I can't get to where the TV is plugged in. It's behind the cabinet on the right someplace. Once I get the TV out I'll be able to get back there, but that presents the problem of once I get the TV loose I'll have to try and hold while my helper unplugs it. I think I'm going to take the easy way out and just cut the power cord. The TV still works but I'll never use it and you can't sell these things so it's going to the e-waste bin anyway.
