msmith1199
Oct 02, 2014Explorer II
I bought a HDMI amplifier that has two inputs and four outputs. So I'll put it in the front cabinet and input the Sat received and a DVD player into it. The outputs will go to the TV's.
And I'm going to still use the existing coax in the motorhome. I'm going to get a smaller coax switch than what was originally in the motorhome, and I'll feed the coax from the Antenna and the outside cable connection into that. Then I'll output from that switch to the existing coax that went to the rear TV and to the front TV. So I'll be able to select the input on the TV's to either get satellite or antenna/coax. I'll just have to throw the A-B switch depending on if I'm using the outside cable connection or the antenna.
