Just bought a 2010 Chateau Citation 29BG B+ with the front entertainment center. There is 32" Jensen TV that is mounted flush to the cabinet with no moldings around it. How do you remove the TV? I ...
tried pulling it straight out and no luck. I wonder if I have to get a screw driver into the rear of the tv mount and unscrew it. Its doesn't look easy but with a mirror perhaps I can try. there is an access to the center section of the entertainment center from the left cabinet so will try that if nothing else surfaces.
