Tom_Barb's avatar
Tom_Barb
Repairing diesel fuel tanks
Our Newmars fuel tank has a 1/2" long crack in the bottom of the tank. It drips about 1 drop in 2 minutes. Yes it is full of fuel.
To drop the tank requires a pit, or jacking the coach very high. requires 36" clearance under the coach, we have done that once, didn't like it.
How would you repair the tank? the tank is aluminum, welding is an option, but requires the tank to be removed and purged. I've welded diesel fuel tanks before but I time they will crack again beside the weld.
I now have an EPOXY patch on it, to stop the drip. but don't trust it to stay. ( the tank flexes that is what caused the crack)
Anyway Ideas ?
  • I'd try welding the crack, grind flat then weld, a larger metal patch across the bottom where the tank flexes. We also had a 2000 NMMA 4092 on a Spartan with a 150 gallon tank but never experienced a fuel leak. Just air bags, and ball joints.
