Ol_Reggie's avatar
Ol_Reggie
Repeated alternator failure
I have a 1988 Ford Econoline chasis Class C Motorhome. My wife was recently returning home in our motorhome and had all of the gauges fail, the seatbelt light came on and the engine shut off. She had the motorhome towed to a mechanic shop where they charged the battery, replaced the alternator and sent us on our way. The motorhome died in the exact same way 1.5 hours later up the highway. the next mechanic told her that the alternator was fine (even though the new alternator was only charging at 12 volts!). They replaced the battery and sent her on her way. The motorhome died yet again 1.5 hours up the road, thankfully just as she was pulling up to the house.
I took the motorhome to a local mechanic and they replaced the alternator and said that it was good to go. I just put a multimeter on the chasis battery and it is 12.4 volts with the engine off, and drops to 12.0 volts when the engine is running!!!
It seems clear that the alternator is not the problem - 2 new alternators charging at 12 volts? Any other thoughts on what the problem might be? I was thinking maybe a failed isolator? The alternator post on the isolator is reading 27 volts and the house battery post is also reading 27 volts (I disconnected the cable from the house battery post).
