bobndot
Oct 17, 2020Explorer III
Water tank would be the largest item IF... the rear pass thru storage area isnt there too. You might not be able to do it. Smaller things under the bed can be heat ducts, water pump, water lines , bypass valves and electrical for your converter panel.
Seatbelt anchoring must be done to the rv frame. Metal chassis not the wood frame.
