Ranger Smith wrote:
Blaster Man wrote:
Are you positive the AH is supposed to provide floor heat? We've had two AHs, neither one heated the floors....they were electric.
I never had an AquaHot provide floor heat either. It was radiant baseboards near the floor that heated the coach. They had a fan on them and threw out the heat. They were hidden in various locations around the coach.
Jayco(Entegra) did run coolant lines in the floor for "Floor Heat". I believe they now have Electric Radiant heating. I figured they realized running water lines front to rear under the floor was not the best way to do that. Doug
