Old-Biscuit
Jan 07, 2016Explorer III
If you have an Atwood WH the electric element is on backside of tank under a cover.
There will be a 12V DC relay (fed from ON/OFF switch----fused circuit from DC Dist. Panel)....relay is used to activate the 120V AC going to element which is fed from a Circuit Breaker in AC Panel. 1400W element used.
Need access to backside of WH.......if none then whole WH has to be removed from outside-----propane disconnected, frame screws removed, pull water heater out enough to disconnect DC and AC wiring then complete removal so element can be accessed.
If you have a Suburban WH the electric element is under small cover behind burner tube in outside compartment.
120V AC directly to element form Circuit Breaker in AC Panel. 1440W element used
38,777 PostsLatest Activity: May 24, 2026
