hershey
Jan 11, 2016Explorer
Before pulling it out, please, please do a continuity check thru the element itself, the limit switches and possible resets on the switches and the possibility of a hidden rocker switch in the water heater itself. As posted above, I was all set to replace my element (possibly the most prone to failure) but did the continuity check and found the hidden switch and it was at fault. Good luck, hope my good luck spreads to you.
38,777 PostsLatest Activity: May 24, 2026
