Commerce's avatar
Commerce
Replacement Dual Pane Window for 2004 Tiffin Phaeton
I have a 2004 Tiffin Phaeton that has a small dual pane window on the lower part of the entry door. The lawn maintenance crew at the last park I stayed in must have kicked up a rock and busted the outer pane because it is now shattered looking and I need to replace it.
Does anyone have a suggestion on where I could find one of these windows and can just the outer pane be replaced or do I have to buy the whole window unit frame and all ?
Thanks for any suggestions you have !
  • After a supply problem, Tiffin bought a glass supplier that now makes their windows. Call Tiffin and drive to Red Bay. The Tiffin folks are great to work with.
  • Thanks for all of the advice guys ! I knew you would come through for me.
  • I agree with others, you show you are from Alabama...give Tiffin a call and see what can be done.
  • I have a 2005 Allegro Bus and was just in Red Bay and had one installed it cost $118.09 for the window plus labor.
  • Since it was in a door I assume that it was safety glass and shattered completely when it broke. ANY glass shop should be able to measure and make you a new panel and install it. Dual pane windows are in houses all over the country and people do not take their stick houses down to Suncoast Designers for repair when a window is broken.
  • RSchleder wrote:
    Give Tiffin Parts & Service Dept a call. Order a replacement which will be the entire window (inside & outer panes) as it's a dual pane unit.
    X-2. They say that Tiffin still has spare paneling for late 1980 wood panels. I once needed a 20 year old ignition switch key (blank from England) and they located me one.
  • Give Tiffin Parts & Service Dept a call. Order a replacement which will be the entire window (inside & outer panes) as it's a dual pane unit. You can probably pay a local auto glass installer a small free for install or try to do it yourself.
    we had several fogged dual pane windows in our MH that needed to be re-sealed. the work was done by Suncoast Designers in Florida. we were very satisfied with the cost and workmanship.
    I bring this up realizing that your window is broken, not fogged because if Suncoast had been unable to re-seal any of our windows they had the ability to cut new pieces of glass. you might give them a call and see if they can ship a piece to you.
