kuzined's avatar
kuzined
replacement fridge
Had posted previously about a fridge replacement. 05 Pacearrow gas which has a side by side Dometic fridge, Want to install a house one in. Avanti brand was mentioned as a perfect slide-in. They are 24in. wide whereas the space I need to fill is 32in.Has anybody found a model that will fill a 60in by 32wide by 27deep space Thanks
  • While not a Dometic, I replaced the Norcold 1200 which is about the same size. I did it myself in a campground in three days...Dennis
    Samsung Install
  • I put this one in mine, yours should be about the same.
    http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/28816594/gotomsg/28817498.cfm#28817498
  • RoyB's avatar
    RoyB
    Explorer III
    You will also need to make sure you can exchange the two fridges through the main door as well I imagine...
    I tried to get a swival lounge chair through the main door with no success...
    Roy Ken
