Wiz's avatar
Wiz
Replace/repair headliner (under cab-over) help/ideas???
2000 Coachmen Santara 311SB class C MH on a Ford F-450 chassis. This coach has a double bed in the cabover. We had significant water penetration over the winter which rotted the wood under the bed. I've replaced and repaired most of the cabover bottom and all the way up to the cabover lights.
The final damage to repair is the headliner over the drivers and passenger seats. This runs from the top of the windshield along the top of the drivers and passenger doors. It was made from thick non-corrugated cardboard panel, covered with vinyl. Along the leading edge across the top of the windshield was a plastic wire wrap. The cardboard got soaked on the passenger side and has crumbled. MDW was able to wash the vinyl and foam for reuse.
It was held up by the sun visors and a button over the drivers and passenger windows. The vinyl was stretched up and stapled to the cutout in the cabover roof.
I have not been able to locate cardboard like this locally. My first attempt was to make a piece out of 1/8 luan plywood but it was too rigid to bend. I then tried 1/8 masonite but it cracked instead of bending. I then tried 1/8 FRP (fiberglass reinforced panel) from Home Depot. I have covered it and installed it but am not happy with the results. The FRP is still too stiff. I ended up with too many waves and wrinkles.
Looking for ideas and alternatives. I have more vinyl that matches so can use a new piece if needed.
  • Hank85713 wrote:
    how about just using FOAM? Get the thickness and size you need cut to shape just like they do in the auto shows on tv. You will just have to glue to the cab and all should be well as it will form just like you want and best of all it will add some noise insulation. Just a thought
    I've been thinking the same thing. I would need a way to attach the vinyl above the windshield then pull it back and over the foam stapling it to the cabover cutout. I should be able to staple the foam to a 2" or so wide 1/4 luan strip of wood then screw that into the steel above the window. I would put slide the wire/cable sleeve over the outer edge to make it smooth for the vinyl. I would glue the foam to the steel using contact cement after cutting it to fit.
  • Have you tried a good art supply / framing store. You can buy pretty long mat board.
  • You might want to contact a GOOD upholstery shop. They may be able to get you what you need. As a thanks, you might want to let them do the reupholster. It shouldn't cost very much, especially if you do the reinstall.
  • how about just using FOAM? Get the thickness and size you need cut to shape just like they do in the auto shows on tv. You will just have to glue to the cab and all should be well as it will form just like you want and best of all it will add some noise insulation. Just a thought
  • tenbear wrote:
    Would a new headliner be available from Ford?
    Haven't checked for a new one but did look for used one. Not much available. I'm going to want to cover in in vinyl so it matches the rest of the front.
