Chris_Bryant
Jul 24, 2018Explorer II
DrewE wrote:
It should be fairly straightforward, though it may take a bit of time and effort. The fuel and AC power connections require removing the starter solenoid, voltage regulator, control module, and the switch/fuse/circuit breaker panel piece in the generator (all of which can be done through the usual access panel on the generator).
What? I've never had to do that- the set comes with the 120 volt leads in place, the fuel connection is external and the battery connections are right up front- ground on the outside, positive is the starting solenoid.
