Dale_Traveling
Aug 02, 2019Explorer II
sailor_lou wrote:
Although mine has past the expiration date I check it's operation every year and since it is still functioning I leave it in place. I've also installed an additional battery operated detector so I have two detectors running at all times. Why discard the functioning unit?
Lou
05 Travel Supreme Envoy
The gas sensors (the front end of the alarm) in CO and LP alarms have a limited life span. After several years of service the manufacture can not guaranty the sensitivity or function of the gas sensor which is why they recommend replacement.
The test button on an alarm tests most of the circuitry but not the gas sensor. Without lab testing the end user has no ability to determine if the sensor can still detect CO at levels that are not harmful to you or LP that is below the explosive concentration level beyond the expiration date.
Alarms cost less than a tank of fuel and take maybe five minutes to replace. Four screws and two 12VDC wire nuts and the old is out and new is in. These are one of the few items that "if it ain't broke don't fix it" might not be best maintenance practice. A bit like tires aging out rather than wearing out.
38,782 PostsLatest Activity: Aug 30, 2026
