- JimMartinExplorer
pkunk wrote:
When I did mine, I ripped & tugged the carpet clear of the staples until I had 95% of it. I cleaned up all the staples as far under as I could see/reach and when I laid the new flooring I only went back under the slide about 6". You'd have to be laying down, cheek to the floor with a flashlight to see any farther in. :)
That's the same model 1999 Coachman Mirada:C - ernieeExploreryou can send me an email- I know about all this stuff
- JimMartinExplorerOK, I'll try that first. Fresh out of fork lifts at this time. LOL!
dbbls wrote:
Extend the slide, lift the carpet flap on the slide and you should be able to see the edge of the main floor carpet. - pkunkExplorerWhen I did mine, I ripped & tugged the carpet clear of the staples until I had 95% of it. I cleaned up all the staples as far under as I could see/reach and when I laid the new flooring I only went back under the slide about 6". You'd have to be laying down, cheek to the floor with a flashlight to see any farther in. :)
- dbblsExplorerExtend the slide, lift the carpet flap on the slide and you should be able to see the edge of the main floor carpet.
- ernieeExplorerNO-YOU DO NOT NEED TO REMOVE THE SLIDE
- jwmIIExplorerRemove the slide out with a fork lift. Not that big a deal with the right equipment.
38,776 PostsLatest Activity: May 15, 2026
